Hi,
I am using Linux Debian 10, I used to use FreeOffice TextMaker with two typing languages English and Persian. I did not have any problem with the app until I upgraded to recent version of TextMaker. There is no problem with English text making. However in Persian text making the followings are the problems I face:
1- Persian language is categorized as Right-to-Left language except for the numbers which are written Left-to-Right. There is no problem with Persian text until I type numbers, numbers are also typed Right-to-Left! for example in a Persian text if I mean to type a number say "1354" ( one-three-five-four) in TextMaker it is typed "4531" when I finish typing the number inside a Persian text.
2- When I open a file with Persian text there is no default font and if the original font is not available in TextMaker nothing will show. means that I have to select all invisible text and then choose a Persian font which is included.
the first problem is such that I can not use TextMaker anymore. any help is appreciated!
<please view the attached files which are basically a test text file typed with freetextmaker. I exported the same file to pdf using text maker and opened the same text file and made another pdf using libreoffice, surprisingly when file is opened in libreoffice numbers are correct. please note the extra explanation in the file concerning my experiment with earlier versions of text maker in opensuse >
Thank you
right-to-left language(persian) works correctly , but not "numbers" !
- test pdfed libreoffice.pdf
- test textmaker text opend and pdfed in libreoffice
- (28.33 KiB) Downloaded 8 times
- test typed text for reporting.pdf
- test textmaker file viewed and pdfed in freetextmaker
- (121.63 KiB) Downloaded 8 times
- test typed text for reporting.docx
- text typed in freetext maker
- (12.76 KiB) Downloaded 9 times
Re: right-to-left language(persian) works correctly , but not "numbers" !
Thanks for reporting this problem. Please share the associated file of TextMaker in which you are getting this problem so that we can do further investigation for resolution.
viewtopic.php?f=321&t=20756
Dear Madam or Sir,
Please see the original message which is edited with files being attached to that, also with some extra explanations.
Regards,
Regards,
Thanks for the files. Also, please share your sminfo file which you can generate by clicking on '?' > About > Write system information.
