Table of Contents option not working
Questions and answers about FreeOffice TextMaker 2018 for Windows
Cammer
Post by Cammer » Fri Sep 11, 2020 8:37 pm
Hi, Freeoffice user manual states indices and table of contents are supported. I'm unable to generate a TOC. The Generate Table of Contents selection box appears, but the selection for Create New or Replace Existing is greyed out and not available. Ideas?
Re: Table of Contents option not working
Post by SuperTech » Sat Sep 12, 2020 2:04 am
Create New or Replace Existing are greyed out because when you first time generate a Table of contents, "Create New table" is the only possible option and by default selected. So, just click on OK after selecting other relevant options and TOC will be there.
Cammer
Post by Cammer » Wed Sep 16, 2020 9:06 pm
Hi,Thanks much. It works.
