[Solved] Move SoftMaker folder from my home directory
General questions and answers about FreeOffice 2018 for Linux. Don't post application-specific questions here, but in the appropriate subforum.
Romrom54
Post by Romrom54 » Wed Jul 15, 2020 4:22 pm
Hi all,
I hope that you are all doing well in this quite special time.
I have a little question. Is there a way to move - without breaking everything - the SoftMaker folder from my home directory for another directory? Is there an option (somewhere in the suite) where I can change/adjust that? :roll:
If I move it on my own, with a move command or a copy/cut and paste, will the suite ask me where is the folder and then I'll be able to tell it?
Thanks for your help :) ,
Romrom54
Re: Move SoftMaker folder from my home directory
Post by martin-k » Wed Jul 15, 2020 5:34 pm
No, this needs to stay at this position.
Romrom54
Post by Romrom54 » Thu Jul 16, 2020 12:44 am
Ok, so it will :).
Thanks martin-k
Roo79x
Re: [Solved] Move SoftMaker folder from my home directory
Post by Roo79x » Wed Oct 14, 2020 2:24 am
I think this is a needed feature. At the very least the SoftMaker team could have the SoftMaker folder as a dot folder
like this
/home/username/.SoftMaker/
That would at the very least hide it from the user directory in Linux anyway.
Return to “FreeOffice 2018 for Linux (General)”
