Remove paragraph styles window
Forum for the beta test of SoftMaker Office 2021 for Linux
vikingson
Post by vikingson » Thu May 21, 2020 8:10 pm
I'm not a big fan of the paragraph styles window on the left in Textmaker. I use small laptops and just don't have the screen real estate to give up that much space. I like the document map on the right, but want to know if I can get rid of Document Styles Window on the left of Textmaker.
Thanks.
Edit: Never mind. I see the window can be shrunk out of the way with the arrow on the side.
Re: Remove paragraph styles window
Post by martin-k » Fri May 22, 2020 8:54 am
Not only that. Using the ribbon command View | Sidebars, you can move all sidebar tabs to the right, into the same sidebar.
vikingson
Post by vikingson » Sat May 23, 2020 2:35 am
Thank You!
Return to “BETA SoftMaker Office 2021 for Linux (General)”
