Screen turning blue
Questions and answers about TextMaker HD for Android
Gemini
Screen turning blue
Post by Gemini » Thu Sep 05, 2019 9:25 am
Hi,
I'm using Text Maker HD on a planet computer Gemini. I've noticed that the screen is taking on a blue tint (this affects the menus and page, it is not a text selection issue) seemingly at random. Last time it happened was when I was using save as to change the name of a document. This tint is only in Text Maker HD, if I go back to the main screen or another app it is fine. The blue tint is reappears if I close and reopen the app.
Regards,
James
Re: Screen turning blue
Post by miguel-c » Thu Sep 05, 2019 10:31 am
Hi, can you send us a screenshot?
Gemini
Post by Gemini » Thu Sep 05, 2019 2:45 pm
Post by martin-k » Thu Sep 05, 2019 3:02 pm
I have no idea what could cause this. The only idea would be that the OpenGL drivers on this device are faulty. I don't think there is anything we can do.
Ren
Post by Ren » Thu Jan 02, 2020 9:48 pm
Ha! I've just downloaded this app and I also have this issue! I thought it was some kind of feature!
Not sure yet, but it seemed to go away and then come back, although it could just have been my eyes adapting. Using an ASUS Chromebook. Goes away on the File load screen btw.
Return to “TextMaker HD”
