default font?
Questions and answers about FreeOffice PlanMaker 2018 for Windows
coffee
default font?
Post by coffee » Sat Aug 17, 2019 4:26 pm
Windows 10, free office2018.
No matter what I do, I cannot save a new template. I have set the template location in the Tools:options:files dialog, and have set the default file format to Planmaker. When I sac=ve a file with the .pmvx extension, the target directory is always the Desktop, not the template directory. When the File:New dialog is opened, the previously saved templates are not found. All I can see is an option for "empty speadsheet". What am I doing wrong?
Re: default font?
Post by miguel-c » Sat Aug 17, 2019 6:47 pm
Please do the following:
1. Close all SoftMaker programs
2. rename your Documents\SoftMaker folder to Documents\SoftMaker_old
3. Start TextMaker, PlanMaker or Presentations. A new Documents\SoftMaker folder will be created automatically, resetting all your settings to default
4. See if the problem is fixed.
Return to “FreeOffice PlanMaker 2018 for Windows”
