Text Maker and Plan Maker cannot input Chinese or Japanese!
Post here those questions, bug reports and suggestions for SoftMaker FreeOffice 2018 for Mac that do not fit in any of the application-specific subforums.
Lim
Post by Lim » Thu Jul 25, 2019 8:16 pm
Hey, I am very happy to find such a great software that can display the doc file on the mac normally.
However, I have a serious problem: Text Maker and Plan Maker cannot input Chinese or Japanese! (But Presentations can do it).
I have tried different input methods, but it still doesn't work.
Text Maker and Plan Maker can only be used to open files and cannot be edited. :(
Re: Text Maker and Plan Maker cannot input Chinese or Japanese!
Post by martin-k » Thu Jul 25, 2019 8:20 pm
Most likely, you don't use the current revision. You need 967. Run "Check for updates".
Lim
Post by Lim » Fri Jul 26, 2019 5:48 am
Hi Martin,
I looked at my version of TextMaker is 967.0716 64bit.
I tried to install on my friend's mac, and I still can't input Chinese. :(
My OS: mac os x 10.10
Post by miguel-c » Fri Jul 26, 2019 6:14 pm
Hi
1. Please go to Home | Options | General
2. Then activate the option Extended support for Asian fonts.
It should work now.
Lim
Post by Lim » Sat Jul 27, 2019 5:23 am
Hi Miguel,
The problem is solved. :D
I recommend activate option on by default, or automatically activate when the interface is switched to Asian language.
Hi
It should work now.
Return to “SoftMaker FreeOffice 2018 for Mac (General)”
