Wrap for long hyperlinks
Post your questions, bug reports and suggestions here for FreeOffice TextMaker 2018 for Windows.
john1030
Post by john1030 » Sun Jun 30, 2019 10:03 am
Please, add a "dumb" wrapping for long hyperlinks.
Step 1. Set language of the Normal character style to "No language". (Personally, I use "No language" because all of my documents have a mix of several languages.) Set its font to Arial 14.
Step 2. Insert some long hyperlink after the asterisk or some text.
Such hyperlink shouldn't have any hyphens inside it. I.e. it should have only slashes, underscores and/or CamelCase. Some examples:
Code: Select all
* https://example.com/foo_bar_foo_bar_foo_bar_foo_bar/foo_bar_foo_bar_foo_bar_foo_bar
* https://example.com/FooBarFooBarFooBarFooBarFoo/FooBarFooBarFooBarFooBarFoo
Note, that hyperlink was moved to the next line. Of course, it looks ugly and it's not what the user wants. An example from real life:
Possible solution: The hyperlinks should wrap on underscores and/or slashes and/or top-right character as well as on hyphens.
Re: Wrap for long hyperlinks
Post by miguel-c » Sun Jun 30, 2019 6:35 pm
Hi, thank you for your feedback! I'm going to report it to the developers.
