Customized Keyboard Shortcuts not saved
Questions and answers about FlexiPDF 2019 for Windows
FlexiPDFUser
Post by FlexiPDFUser » Wed Jun 05, 2019 8:01 pm
We use Trial Licence of FlexiPDFPro 2019 (V 2.0.2) and think to have found a bug.
The Keyboard Shortcuts aren't saved permanently. After program restart the options are back to default.
Funktionsleisten-Einstellungen -> Schaltflächen hinzufügen oder entfernen - > Anpassen -> Tastatur
It's reproducible on different systems, tested with Windows 7 and 10.
Re: Customized Keyboard Shortcuts not saved
Post by miguel-c » Wed Jun 05, 2019 10:58 pm
Hi, I was able to reproduce the issue you described and I'm going to report it to the developers.
Thank you for your feedback!
Return to “FlexiPDF 2019 for Windows”
