No double-sided print option
Questions and answers about FlexiPDF 2019 for Windows
Dicky
Post by Dicky » Tue Mar 26, 2019 2:34 am
Can't see/find an option for double-sided printing (which works for me on other Softmaker software - e.g. the SoftMaker Office suite for Mac.
This is a big downside and a barrier for me to purchase right now.
Re: No double-sided print option
Post by sven-l » Fri Mar 29, 2019 11:16 am
Duplex print is handled by the printer driver, not FlexiPDF. You have to enable it in the print options in the print dialogue.
FlexiPDFUser
Post by FlexiPDFUser » Wed Jun 05, 2019 7:45 pm
Hello
We are currently evaluating FlexiPDF2019 and our users have exactly the same request.
They are missing the double-sided print option in the first print dialog. We have to print allot of PDF documents but only about half of them double sided, it depends on the document and therefore always going in the properties menu of printer driver is no solution in our workflow.
It keeps us from purchasing a 10 User licence for our terminalserver environment.
Please consider to add this option.
Thank you
Post by miguel-c » Wed Jun 05, 2019 7:49 pm
Hi, there's a trick you can do: you can create a duplicate of your printer in which the duplex is turned on.
Example:
Imagine you have an "HP 1000". You could create a copy of the printer called "HP 1000 - Duplex".
You could also create copies for different printer settings, for example: HP 1000 - Black & White"
FlexiPDFUser
Post by FlexiPDFUser » Wed Jun 05, 2019 8:22 pm
Example:
Good idea, we will try this.
Thanks!
Return to “FlexiPDF 2019 for Windows”
