BAK files issue?
General questions and answers about FreeOffice 2018 for Windows. Don't post application-specific questions here, but in the appropriate subforum.
utkuluk
BAK files issue?
Post by utkuluk » Sat Mar 23, 2019 12:20 am
I search forums for "bak file", and only one topic about my issue comes up, and that didn't solve it.
I mean, I don't want to disable backup option but:
1) Why they are not stored at some common folder?
2) Forget that, why they are not even hidden?
Just because of this disturbing bak files I was about to delete this program, I wanted to ask about this in here before I do.
Re: BAK files issue?
Post by martin-k » Sat Mar 23, 2019 8:46 am
I have moved your post to the correct forum, since it is about FreeOffice.
SoftMaker Office supports multi-generational backup in a common folder. FreeOffice has one generation of backup files in the same folder as the document.
utkuluk
Post by utkuluk » Sat Mar 23, 2019 10:17 am
Time to uninstall it.
Post by martin-k » Sat Mar 23, 2019 10:46 am
I suggest then that you stay clear of Microsoft Office as well because it does it the same way as FreeOffice (only that backup files are off by default).
Return to “SoftMaker FreeOffice 2018 for Windows (General)”
