Can't activate the program
Questions and answers about FlexiPDF 2019 for Windows
REP
Post by REP » Thu Feb 28, 2019 2:06 pm
The product key which I got when I bought the program is continually rejected. Does anyone else have this problem?
Re: Can't activate the program
Post by martin-k » Thu Feb 28, 2019 5:21 pm
What is the error message? Also, please verify that you try to enter the key in FlexiPDF 2019 and not 2017.
REP
Post by REP » Fri Mar 01, 2019 3:11 pm
Internal error (-7)
Post by sven-l » Thu Mar 07, 2019 3:52 pm
There are no other customers reporting this issue. Are you working behind a proxy server? It is possible that FlexiPDF cannot reach the license server.
kenj
Post by kenj » Wed Apr 10, 2019 10:46 pm
I reported this problem within the last week. Support suggested Comodo Firewall may be the problem.
I spent the last few days trying everything connected with antivirus/firewalls. Nothing works with regards to Windows10 64 Bit (vmware & virtualbox).
Tried one last time in Win 7 64 Bit (virtualbox) with exact same Comodo and DID NOT disable anything and the activation completed flawlessly.
I had no trouble with Flexi 2017 on either Win 10 machines.
Hope this helps
kenj
Post by kenj » Sat Jun 08, 2019 2:16 pm
Activation now working correctly with Windows 10 1903 Update. :D
Post by miguel-c » Sat Jun 08, 2019 5:04 pm
So after you updated Windows 10 to 1903, it suddenly activated?
Return to “FlexiPDF 2019 for Windows”
