Printer Driver seems not to work anymore
Questions and answers about FlexiPDF 2019 for Windows
Re: Printer Driver seems not to work anymore
Post by martin-k » Thu Feb 28, 2019 8:16 pm
Just to be sure: Do you see the PDF files in c:\ProgramData\TEMP? (look at the timestamp to verify you are looking at current files)
In that case, it seems like you are not running FlexiPDF 2.0.1 but 2.0.0. That was the exact problem that got fixed by 2.0.1.
tbidd17
Post by tbidd17 » Fri Mar 01, 2019 2:07 pm
The version I have is 2.0.1, that is what shows when I click the Help and About buttons. And yes I am able to find them by the timestamp in the temp file folder.
tbidd17
Post by tbidd17 » Wed Mar 06, 2019 1:58 pm
Anything else I can try? If not I will have to download another program.
Post by sven-l » Wed Mar 06, 2019 3:28 pm
In the temp folder (C:\ProgramData\TEMP) there should be an .ini file created together with the PDF file. Could you please send us both files to forum(at)softmaker.com referring to this thread or attach them here? Both files would help the developers to find out what's wrong with your installation.
tbidd17
Post by tbidd17 » Wed Mar 06, 2019 5:04 pm
Not sure if this is the file your referring to, but here is the file located right beside the PDF and the PDF itself.
2019-03-03.13.52.43.24-00012.PDF
(290.33 KiB) Downloaded 35 times
2019-03-03.13.52.43.24-00012.ini
(2.3 KiB) Downloaded 33 times
Post by sven-l » Thu Mar 14, 2019 3:18 pm
Thank you! I cannot even reproduce that issue with your sample file but I will report this to the developers.
n-p
Post by n-p » Thu Apr 04, 2019 4:42 pm
The problem concerning the clipping masks that appeared when printing e-mails as PDFs has been fixed by the developers.
It shouldn't occur any longer with future versions of FlexiPDF 2019.
Return to “FlexiPDF 2019 for Windows”
