cannot open file from cryptomator vault
Post your questions, bug reports and suggestions here for FlexiPDF 2017.
makan
Post by makan » Wed Jan 09, 2019 9:58 am
hi team,
since my cryptomator upgraded to latest version, i cannot open any pdf file from my vault anymore.
i should copy it first to drive c: or d: before i can open my pdf file.
any workaround for this issue?
Re: cannot open file from cryptomator vault
Post by sven-l » Thu Jan 10, 2019 1:45 pm
Does it work with other PDF viewers like Acrobat Reader?
makan
Post by makan » Mon Jan 14, 2019 5:50 am
yes acrobat reader can open it from cryptomator vault properly
opened with acrobat reader
Post by sven-l » Fri Jan 18, 2019 9:26 am
Pleas try uninstalling and the installing FlexiPDF again. Does that work?
makan
Post by makan » Wed Jan 23, 2019 11:50 am
hi sven,
after i re-install felxipdf, i can open a pdf file from menu File - Open.
however i still cannot open a pdf file if i directly double click it on File Explorer (vault drive)
Post by sven-l » Wed Jan 23, 2019 5:00 pm
Try right mouse click on the PDF file, then "Open with..." and select FlexiPDF. Here you can enable the option that sets FlexiPDF as the default program for PDF files.
makan
Post by makan » Wed Jan 30, 2019 6:15 am
hi sven,
yes, it could be good workaround.
thank you for your help 8)
Return to “FlexiPDF 2017”
