Animations fail to run
Post your questions, bug reports and suggestions here for Presentations 2016 for Windows.
snowshed
Post by snowshed » Mon Dec 31, 2018 11:34 pm
I have a slide with 7 text frames.
Frame 1 is the same size as the slide, and I use it for aligning and distributing frames on the page.
Frame 2 is used for the title on the slide.
Frames 3-7, I want to have them appear in order, with a mouse click or spacebar press, with a diamond transition.
When the Animations dialogue is open, and I individually test each frame, the diamond transition works.
However, when I run the slide, the animation for frames 4 & 6 do not work. The simply appear on the screen.
What have I missed? :)
Re: Animations fail to run
Post by sven-l » Mon Jan 07, 2019 5:26 pm
Please attach a sample file or send it to forum(at)softmaker.com.
snowshed
Post by snowshed » Mon Jan 07, 2019 8:04 pm
Do you want the whole presentation, or just the affected slide?
Post by sven-l » Tue Jan 08, 2019 9:58 am
The affected slide should be enough. Thank you!
snowshed
Post by snowshed » Tue Jan 08, 2019 8:57 pm
The slide is attached.
Thanks, Sven.
Animations do not run.prd
(912.5 KiB) Downloaded 6 times
Post by sven-l » Thu Jan 10, 2019 1:01 pm
I can reproduce that issue with Presentations 2018 and will inform the developers.
Post by sven-l » Thu Jan 10, 2019 2:06 pm
According to the developers, this happens only if you press the space key too fast, before the previous animation is over.
If you wait long enough (the duration of every animation is set to 2 seconds), all animations are played correctly.
snowshed
Post by snowshed » Thu Jan 10, 2019 2:07 pm
Thank you, Sven.
snowshed
Post by snowshed » Thu Jan 10, 2019 4:52 pm
So it does!!! :-)
Thanks, Sven, and please thank the developers for me, too.
Return to “Presentations 2016 for Windows”
