Change default character font template
Questions and answers about FreeOffice TextMaker 2018 for Linux
PRafael
Post by PRafael » Sat Dec 08, 2018 6:44 pm
Hi all.
First, thanks for this software FreeOffice 2018, it's really amazing and easy to use it.
Second, after last update I cannot change the default font character...after selecting it and pressing the button to define it, it gives the error that it cannot find "Normal.tvmx"...but the path is correct.
Info: FreeOffice 2018 (rev. 942.1130) 64 bit.
Thank you for helping
Regards
Paulo
Re: Change default character font template
Post by sven-l » Thu Dec 13, 2018 12:39 pm
Please rename the folder "SoftMaker" in the Documents folder. This will re-create all template on the next start.
Return to “FreeOffice TextMaker 2018 for Linux”
