Editing Text Does Not Work - FlexiPDF Pro 1.10
Post your questions, bug reports and suggestions here for FlexiPDF 2017.
moneillqs
Post by moneillqs » Sat Jun 23, 2018 2:47 pm
I purchased a Pro version of FlexiPDF via a special offer a couple of weeks ago. I understood that I could install this on up to 3 PCs. I have it installed on 2 personal laptops. It seemed to be working fine until I upgraded to v1.10. Editing works fine on one but not on the other. The select object arrow on the second laptop seems to be disabled and whilst I can open a text box, it does not receive any new text input.
The software seems to be activated properly on the second laptop.
Re: Editing Text Does Not Work - FlexiPDF Pro 1.10
Post by sven-l » Tue Jul 03, 2018 2:44 pm
It looks like it is activated as a Standard and not a Professional version. Please uninstall FlexiPDF and install it again. Does it help?
moneillqs
Post by moneillqs » Sat Jul 07, 2018 3:53 pm
I have uninstalled and then re-installed v1.10. This has not solved the problem. When I right click in a text box, the only thing I can do is select all, copy and change the background colour. I cannot add text or delete text.
Post by martin-k » Sat Jul 07, 2018 4:04 pm
Can you send the PDF file to forum (at) softmaker.de ?
Return to “FlexiPDF 2017”
