accented characters
Questions and answers about FreeOffice TextMaker 2018 for Linux
kgha
accented characters
Post by kgha » Sat May 19, 2018 11:45 am
trying out FreeOffice 2018 I notice that the issue I reported testing the 2018 beta hasn't been solved - see viewtopic.php?f=294&t=17394
It's one of the main reasons why I have refrained from upgrading my Office 2016 (which is also affected). It would be good to know if the developers are trying to find a solution or if it has been decided that the issue is to be neglected.
Running slackware64 -current, MATE desktop, Swedish keyboard.
miansancor
Re: accented characters
Post by miansancor » Wed Sep 05, 2018 5:53 pm
It is the very same problem for me. And also for me this is the MAIN problem to buy the commercial application.
To me is the very same problem with spanish, is does happens THE SAME I can not write any accented vowel, it writes the accent first and then the vowel: they appear, instead: 'a, ~a, ^a . In all the other office applications it does not append.
Thanks for any help!
Spanish keyboard, opensuse cinnamon, tumbleweed.
Post by sven-l » Thu Sep 06, 2018 11:13 am
SoftMaker Office and also FreeOffice requires your system to use UTF8.
Return to “FreeOffice TextMaker 2018 for Linux”
