Suggestion about default font
General questions and answers about FreeOffice 2018 for Linux. Don't post application-specific questions here, but in the appropriate subforum.
NX-01
Post by NX-01 » Thu May 17, 2018 4:17 pm
Hi. I just got the 2018 free version. I gotta say it's a lot easier program to work with than LibreOffice, so I'm staying with FO2018. However, I'd like to suggest something:
a) make an option where we can manually select the default font to be used for all of our documents, so that when we open the program, we won't have to choose fonts every time
OR
b) make the program remember the font we used the last time.
P.S. I also have a question: how can I disable the side bar welcoming screen? I can hide it temporarily but when I open the program again, it returns.
Re: Suggestion about default font
Post by sven-l » Wed May 23, 2018 11:54 am
We are working on the issue that the sidebar appears on every start. This should work better with future updates. I will refer your suggestions to the product management.
Post by Jossi » Fri May 25, 2018 7:15 pm
OR
To change the default font permanently, you have to edit your standard document template. The procedure is described here.
Return to “FreeOffice 2018 for Linux (General)”
