disable drag and drop
HumboldtSteve
Is there a way to disable drag and drop editing in Softmaker Office?
Re: disable drag and drop
Do you mean drag&drop of objects inside of a TextMaker/PlanMaker file?
HumboldtSteve
Yes. It's too easy to highlight text and suddenly find it moved.
I will refer a feature request to the produce management to add such an option.
+1 to feature request. It was a surprise when such must-have option was not found in pro version. Especially annoying when selecting region in PlanMaker and first cell dragging over instead of selecting.
- Contact:
Apart from the two users posting in this thread, we never had a complaint about drag & drop. Could you please describe in more detail what you are doing that causes an erroneous drag & drop?
Goodness, this is an old thread. But this feature/bug is still a problem for me. When I select text, I have to be very careful not to drag some characters with the cursor instead of just cleanly selecting. Sure, I can just hit Ctrl-Z and try again more carefully, but I'd LOVE to just turn this off. I never use it, anyway, because it's more precise and less stressful to use keyboard commands.
Yes, this thread is in a forum section for a much older version. Could you please tell me which version of SoftMaker Office you are currently using?
If it is SoftMaker Office 2018, I recommend trying the current SoftMaker Office 2026. Version 2018 is no longer supported, so any corrections will only appear in the current generation, SoftMaker Office NX and 2026.
