Decimal Tabs
Post your questions, bug reports and suggestions here for FreeOffice TextMaker 2016 for Windows.
bfree380
Decimal Tabs
Post by bfree380 » Wed Mar 14, 2018 2:54 pm
We are trying to open an rtf which has decimal tabs in it. In word, and even in TextMaker Viewer, it shows up/lines up correctly. However, in FreeOffice TextMaker, they don't line up at all properly. Is there any way to fix this?
Thanks.
Re: Decimal Tabs
Post by sven-l » Wed Mar 21, 2018 4:55 pm
Pleae provide a sample file or send it to forum(at)softmaker.com.
bfree380
Re: Decimal Tabs
Post by bfree380 » Thu Mar 22, 2018 12:33 pm
I've attached a sample file of what we use. The first half of the document is fine, but under expenses, it is not formatting correctly. It comes out fine in MS Word and TextMaker Viewer, but not in TextMaker. Thanks for your help.
001-GLFReports-FA.rtf
(4.26 KiB) Downloaded 70 times
Re: Decimal Tabs
Post by sven-l » Mon Mar 26, 2018 1:17 pm
I opened your file with MS Word 2013, TextMaker 2016 and TextMaker 218 and could not see a difference. Could you please attach a screenshot to show what exactly you mean?
bfree380
Re: Decimal Tabs
Post by bfree380 » Thu Mar 29, 2018 6:20 pm
Sorry, I think I may have uploaded the wrong file. Here is the correct one.
001-GLFReports-FSB.rtf
(58.3 KiB) Downloaded 67 times
Re: Decimal Tabs
Post by sven-l » Mon Apr 09, 2018 4:22 pm
The file looks good with TextMaker 2018, so please try again with FreeOffice 2018 as soon as it is available.
bfree380
Re: Decimal Tabs
Post by bfree380 » Tue Apr 10, 2018 2:08 pm
Okay, I just downloaded the file that I had uploaded, then opened it directly in Textmaker (rev 767.0516) and it doesn't show correctly at all on my computer. I've uploaded a snip of what it looks like, highlighting a few of the issues. you can see that the decimals aren't lining up at all when it is just a decimal without a whole number, or when there is a negative.
Thanks for you assistance.
Re: Decimal Tabs
Post by sven-l » Tue Apr 10, 2018 2:44 pm
You can change the decimal separator for your file in File=>Properties=>View from comma (,) to dot (.). this fixed the problem on my side.
bfree380
Re: Decimal Tabs
Post by bfree380 » Tue Apr 10, 2018 2:50 pm
It already is a decimal (period).
Re: Decimal Tabs
Post by sven-l » Tue Apr 10, 2018 2:57 pm
Please make sure that the correct decimal symbol is set in the Windows control panel (regional settings). TextMaker 2016 and 2018 both rely on these settings. If I change the decimal separator in the Windows 10 settings on my machine, it is also automatically changed in TextMaker in File=>Properties=>View.
bfree380
Re: Decimal Tabs
Post by bfree380 » Tue Apr 10, 2018 5:18 pm
I have verified the settings are correct.
Return to “FreeOffice TextMaker 2016 for Windows”
