Edit the List Number Style
snowshed
Post by snowshed » Fri Feb 23, 2018 11:24 pm
Windows 7 Ultimate
When I use the List Number Style, I get output that looks like this:
1.. Blah blah blah blah blah blah blah blah blah blah blah
2.. Blah blah blah blah blah blah blah blah blah blah blah
3.. Blah blah blah blah blah blah blah blah blah blah blah
4.. Blah blah blah blah blah blah blah blah blah blah blah
Please not the 2 periods after the number.
Is there a way to edit that style so there is only 1 period? I do not see a way to do that when I click Edit.
Re: Edit the List Number Style
Post by sven-l » Fri Mar 02, 2018 4:07 pm
Could you please attach a sample file? That would help us to find out what's wrong here.
snowshed
Post by snowshed » Sat Mar 03, 2018 4:42 pm
Attached. :)
I have been experimenting with modifying and creating my own styles, but the problem has shown up in 2 documents.
Thanks you.
Windows 10 Basics.tmd
(57.43 KiB) Downloaded 146 times
Post by Jossi » Sat Mar 03, 2018 7:43 pm
In editing the number list format, you added a full stop (period) in the field "Numbering text". This isn't necessary, as it is added automatically by the program. Delete it, and everything is o. k. (see attached screenshot).
snowshed
Post by snowshed » Sat Mar 03, 2018 9:24 pm
Thanks, Jossi,
I don't remember ever being in that dialogue before, in fact I don't remember even using the list number style or even a numbered list in Textmaker until these last two documents.
I always try different programs for a purpose, then settle on the one I like the best.
As a result, I was using the Free Office version for a bit a long, long time ago. When I settled on Softmaker Office and purchased it, could that extra period have been somehow carried over from something I did a long time ago?
Post by Jossi » Sun Mar 04, 2018 12:57 am
To check this, I unearthed and tried an old copy of FreeOffice from 2014, and it seems you are right: In the "Simple Numbering" list style in this program, no period is shown behind the number in the edit dialogue, but it is added in the text; in TextMaker 2016, the period is also visible in the dialogue box (see attached screenshots). So obviously there has been a change somewhere between. If you opened an old document created with FreeOffice in TextMaker 2016, maybe this caused the issue.
snowshed
Post by snowshed » Sun Mar 04, 2018 5:16 am
No, I didn't open a doc created in Free Office 2014. If I even have one, I don't know where it would be, as it would have been just something to get the "feel" of the program.
It might be worth checking this out in 2018, to see if the problem exists there also.
Post by Jossi » Sun Mar 04, 2018 11:38 am
Might be that an old preference option persisted, but I'm out of my depth here. SoftMaker should have a look at this issue.
snowshed
Post by snowshed » Sun Mar 04, 2018 4:45 pm
That could be. It shouldn't take too much time for SoftMaker to do a fresh install of 2018 on a virgin machine to see if the extra period is there. If it is, there's a minor bug. If not, then put an older version on a virgin machine, add that period, the install 2018 on top of the older version and see what happens.
Post by sven-l » Mon Mar 05, 2018 3:54 pm
I will check this here.
