Tmd or Doc which is the best format I should save in...
General questions and answers about SoftMaker Office 2016 for Windows. Don't post application-specific questions here, but in the appropriate subforum.
lori67k
Post by lori67k » Sun Jul 02, 2017 7:30 am
I just installed your software in trying to find a good alternative to Microsoft 365 Word, because monies were a bit tight this month and I love that this software is free, however, when I opened one of my word docs to edit and then save using your textmaker, I saved a copy using the .tmd format but then it dawned on me... what if I want to go back to using Word from microsoft? Is the tmd format going to be an issue with docs edited and/or created using this format in textmaker, within the Word program if I go back to using it?
Should I save these files in doc format instead?
The word docs are automatically saved as docx format with Microsoft 365, so I am unsure which doc format version textmaker offers would be the best, should I return to word since docx is not available in your program. There are only 2 doc format options available in the 'save as' window upon saving. These two formats are:
Microsoft Word 97-2003 .doc
and
Microsoft Word 6.0/95 .doc
Which one would you recommend I save in to ensure I can open up word documents should I switch back?
Another question (related) to this one is... can I select one of the doc formats as the default save option?
If so, how would I go about setting .doc format as the default option in textmaker?
Thank you for your time :)
Re: Tmd or Doc which is the best format I should save in...
Post by sven-l » Fri Jul 07, 2017 7:40 am
.tmd can only be opened by TextMaker, but if you decide to go back to Microsoft, you can still open .tmd files and save them as .doc.
Word 97-2003 is the more modern option compared to Word 6, and just as compatible.
You can set the default file format in Tools > Options > Files.
lori67k
Post by lori67k » Sat Jul 08, 2017 2:33 am
oh awesome :) thank you
