Thunderbird auto fill not working
Questions and answers about Thunderbird for Windows
keitn_hodgson
Post by keitn_hodgson » Mon May 15, 2017 5:20 pm
Following an update to Thunderbird the recipients addresses are not showing in the address bar, usualy there is a list however now the letters appear in red indicating that the email address is not in the address book. when checking the settings; Tools, compose Local is checked directory is checked but blank, edit directory pain is also blank. How do I fix this issue please. Or what else should I be looking at please.
The address book is there with all the addresses, I don't know how to find the address book file?
Re: Thunderbird auto fill not working
Post by martin-k » Mon May 15, 2017 5:25 pm
You updated Thunderbird, but didn't update the add-ons. See:
http://www.softmaker.com/en/blog/en-gb_ ... derbird-52
keitn_hodgson
Post by keitn_hodgson » Mon May 15, 2017 5:34 pm
I have looked at the link but don't see how to do the add on update, I must be missing something. Many thanks.
Post by martin-k » Mon May 15, 2017 5:39 pm
First of all, please make sure that you're already using the latest version 52.1.0 instead of the slightly outdated versions 52.0 or 52.0.1 which still contained a number of bugs. To do so, please launch Thunderbird, invoke Help > About Thunderbird and click on Check for Updates.
In a second step, you should refresh the SoftMaker add-ons. Please open the add-ons manager (Tools > Add-ons), click on the gear-wheel icon in the top right of the window and choose Check for updates from the dropdown list.
keitn_hodgson
Post by keitn_hodgson » Mon May 15, 2017 5:41 pm
I have the 52.1.0 update (32bit) however my Win 10 is 64bit, is this an issue
keitn_hodgson
Post by keitn_hodgson » Mon May 15, 2017 5:54 pm
Hi
I finally managed to find the correct page and the settings, then a restart on Thunderbird and all seems well now.
Thank you for your help.
Return to “Thunderbird for Windows”
