Small Caps function not working correctly
Post here those questions, bug reports and suggestions for SoftMaker FreeOffice 2016 for Windows that do not fit in any of the application-specific subforums.
lrollo
Post by lrollo » Sun Jan 22, 2017 11:46 pm
Textmaker v 763
I usually start a major document or document section with a small caps phaseby selecting the phrase and navigation to the appropriate dialog to invoke small caps.
When I close and reopen the document, the small caps have spread to convert all the text in the paragraph to scaps
Is this a glitch/bug OR am I missing some step to fix the scaps only to the selected text
Re: Small Caps function not working correctly
Post by sven-l » Wed Jan 25, 2017 2:10 pm
In which file format (.doc, docx, tmd, rtf...) are you saving the file?
Dirge
Post by Dirge » Wed Feb 01, 2017 3:31 am
I can confirm the problem when saving to .rtf; there is no problem when saving to .doc, .tmd, or .odt.
Windows XP (SP3)
Athlon XP 3000+ CPU (w/o SSE2)
TextMaker 763.1202
Post by sven-l » Fri Feb 03, 2017 10:19 am
Caps handling in rtf does not work properly at the moment. The developers are working on it. Please use .doc or .docx instead. Thank you!
Return to “SoftMaker FreeOffice 2016 for Windows (General)”
