Workbook index
Questions and answers about PlanMaker 2016 for Windows
Princy557
Workbook index
Post by Princy557 » Wed Sep 21, 2016 9:03 pm
HI,
Not sure what to call this.....
But I would like to create a basic workbook which contains all the workbooks names that I use on a regular basis.
All I want to do is for the Planmaker to load this as a default book, then for me to click select the workbook I want to use , click on it and it should open in the current Planmaker as a workbook?
Regards
Princy557
Re: Workbook index
Post by martin-k » Wed Sep 21, 2016 9:05 pm
In a cell, type the name of the workbook file (or some other indicator that shows you which file it is), then call Format/Link and enter the path+file name. Repeat with all other workbooks for which you want to create this index file.
Princy557
Re: Workbook index
Post by Princy557 » Wed Sep 21, 2016 9:13 pm
Hi Martin,
Thanks for the quick reply, will give that a go in half an hours time....
:D
Regards
Princy557
Princy557
Re: Workbook index
Post by Princy557 » Wed Sep 21, 2016 9:41 pm
HI,
Works a treat, thanks for that.
is there a way to get a workbook to load as a default?
Regards
Princy557
Re: Workbook index
Post by martin-k » Wed Sep 21, 2016 9:44 pm
Pass it in the command line: PlanMaker.exe filename.xls
But much more simple: Create a shortcut to this document on the desktop. Double-clicking the shortcut will start PlanMaker and load the file into it.
Princy557
Re: Workbook index
Post by Princy557 » Fri Sep 23, 2016 2:49 pm
Hi Martin,
Yes that all worked well thanks for the quick response.
I've been a little busy. ancient mother in law staying so get distracted doing her bidding :D :o
I had a little bit of a problem with editing the shortcut so that it would accept the .pmdx file, but it turned out to be a typo and an extra pair of " stuck on the line.
All working wonderfully now. Thanks again.
Regards
Princy557
Re: Workbook index
Post by martin-k » Sat Sep 24, 2016 10:40 am
Glad to hear you were able to implement this as desired.
