Url mishandling when exporting to pdf
Levente
Post by Levente » Thu Mar 03, 2016 2:48 pm
I have a document that has links to my dropbox folder. If I export the document to pdf the links are changed and the source path on my local machine is appended to the beginning of the url.
See sample doc.
I'm using TextMaker 2016 (rev. 751.0208). Am I doing something wrong?
This is a link to.pdf
(53.47 KiB) Downloaded 204 times
This is a link to.tmd
(9.54 KiB) Downloaded 115 times
Jim-J
Re: Url mishandling when exporting to pdf
Post by Jim-J » Thu Mar 03, 2016 5:13 pm
Please install the newest service pack (rev751.0224) http://www.softmaker.com/en/servicepacks-office-windows and check this issue again.
Jim J.
Levente
Post by Levente » Thu Mar 03, 2016 6:15 pm
I upgraded, but the behaviour is the same - not corrected.
Post by Jossi » Fri Mar 04, 2016 10:56 am
Does it help to check/uncheck "Use relative paths for file links“ in the PDF export dialogue box (tab "Preferences", lower left corner)?
Levente
Post by Levente » Fri Mar 04, 2016 1:51 pm
Jossi wrote:Does it help to check/uncheck "Use relative paths for file links“ in the PDF export dialogue box (tab "Preferences", lower left corner)?
Thanks, I checked the checkbox and urls are exported in the correct manner.
