SD card support?
General questions and answers about SoftMaker Office HD for Android. Don't post application-specific questions here, but in the appropriate subforum.
hpham
SD card support?
Post by hpham » Mon Dec 29, 2014 1:19 pm
When I attempt to open a spreadsheet from an SD card, I receive an error that the file is in use and if I would like to open the file read only. If I try to open the same file copied to the internal memory, it opens fine. So it appears that Planmaker does not yet support SD cards? If so, will this feature eventually be added? I'm using the trial version on a Samsung Galaxy Tab Pro 8.4.
Thanks.
Re: SD card support?
Post by sven-l » Wed Jan 07, 2015 9:22 am
Well, it seems that you use Android 4.4. SD card support is limited with that version:
http://www.softmaker.com/english/tipsandroid_en.htm
hpham
Post by hpham » Wed Jan 07, 2015 9:37 am
Yes, I am on 4.4. Hopefully, Samsung will provide an update to Lollipop soon. Will that correct the issue? Thanks.
Post by martin-k » Wed Jan 07, 2015 9:45 am
Google claims so.
Painter
Post by Painter » Mon Feb 01, 2016 4:44 pm
TextMaker will not save to physical external SD card even with Android 5.0. It says the drive is full [or busy.] Other office suites already support saving to external SD card in Android 5.0. Can you tell me when this will be fixed? Thank you very much!
Jim-J
Post by Jim-J » Tue Feb 02, 2016 12:16 pm
Please wait for the next service pack. Then is should work.
Jim J.
RobW
Post by RobW » Mon Mar 14, 2016 8:55 pm
I can confirm that reading and writing to and from external SD card works now.
Thanks.
RobW
fjbailey3
Post by fjbailey3 » Sun Apr 17, 2016 12:33 am
I would in interested in knowing how to access an external SD card from Textmaker HD. I'm not offered that choice, only Device Memory (and a bunch of cloud stuff that I won't use).
Rick B.
Post by sven-l » Mon Apr 18, 2016 11:24 am
fjbailey3 wrote:I would in interested in knowing how to access an external SD card from Textmaker HD. I'm not offered that choice, only Device Memory (and a bunch of cloud stuff that I won't use).
Rick B.
Please wait for the next service pack. Then it should work.
fjbailey3
Post by fjbailey3 » Mon Apr 18, 2016 3:27 pm
Thanks. Good to know it's in work, I can certainly wait.
Rick B.
Return to “SoftMaker Office HD for Android (General)”
