I LOVE that Presentations is adding a notes pane under the slides in SLIDE VIEW. I found a bug:
When you use bullets and hit TAB to INDENT, the indent happens but does not show up. I must switch to NOTES view to see the indents, and then when I switch back to SLIDE view the notes pane shows these formatting changes (see pictures)
Bug in new slide view notes pane
Re: Bug in new slide view notes pane
I was able to reproduce the issue and reported it to the developers. Thanks!
The issue has been fixed and the fix was be included in the next beta version.
