track changes / add comments in text frames
Devonboy78
Post by Devonboy78 »
When tracking changes is set to ON {File - Properties - Review - Track changes }, changes are tracked within text frames but it seems that you cannot add a comment within the text frame. This means that if documents contain text frames, you cannot add a comment within a frame but can only add a comment before or after the frame, not particularly helpful especially if the text frame contains a lot of text which requires several edits.
Re: track changes / add comments in text frames
It wOuld be nice, but unfortunately, comments inside text frames are not Word-compatible.
Devonboy78
Thanks for reply. Haven't used Word for years so didn't realise that wasn't possible in Word
Return to “BETA TextMaker 2024 for Windows”
