Bug reports and suggestions
DE742730
Post by DE742730 »
Hello,
I played around with TextMaker NX Universal - Nightly (rev S1106.0331) 64bit for Windows today and noticed the following issues. I can provide sample files and/or screenshots if needed.
TextMaker
  • SUGGESTION PLEASE add support for Croatian language (document translation, not UI - though I could help with UI translation, if needed)
  • BUG Charts - parts missing
  • BUG Objects - text objects created in Word displayed incorrectly (position, font color)
Presentations
  • BUG Charts - not shown at all
Keep up the great work, loving some of the improvements you made. Still can't get used to the red color for TextMaker tho :?
Kind regards,
Vladimir
DE742730
Re: Bug reports and suggestions
Post by DE742730 »
BUG In TextMaker, when Rows are added or removed from Tables, font size is being reset in first column (perhaps also in other columns).
DE742730
Post by DE742730 »
In Presentations, there seems to be a problem with Colors Schemes. Yesterday, while creating a presentation, colors displayed under Slide Color Scheme did not match. For example, I would click orange, and would get blue (which is in the same place but in another color scheme). Today I reopened the same presentation, and the colors used for cell shading have changed, but the color scheme in the color menu (Slide Color Scheme) now work as they are supposed to.
DE742730
Post by DE742730 »
Is anyone even reading this?
Devonboy78
Post by Devonboy78 »
Re DE742370 'BUG In TextMaker, when Rows are added or removed from Tables, font size is being reset in first column (perhaps also in other columns)'
In TextMaker NX Universal - Beta (rev S1110.0427) 64bit , there is no evidence of change in size of font in first or any other column when a row olr column is added or deleted.
For each bug, could you please send example files and, in possible, animated GIFs or images.
You can use the free (and safe) software screentogif from screentogif.com
Return to “BETA SoftMaker Office 2024 for Windows (general)”
