Comments/Issues
kelly6754
Comments/Issues
Post by kelly6754 »
Positive:
This app seems the easiest/most intuitive for me to use out of the three.
I like the Export and Send options.
The customer support avenues are definitely there.
I like the different slide formats, such as summary slide and outliner.
I like that I can create Notes.
I can easily find out what things are and what they do.
Issues/Observations:
No Welcome Page or Sample Page was there.
The Animation procedures looked rather cumbersome. Everything else looks pretty straightforward, so I had adjust my eyes for that section.
Under Animation Properties, the Sound tab doesn't display properly, and the File... button covers an area of text.
I like the slide design color options and schemes, but the color options aren't as comprehensive as the other apps in terms of range. I am glad there are free options though.
At first, I had problems with the Send options, particularly the .prdx and .prd extensions, but after saving and taking my time to explore and retry sending, this problem worked itself out for me on its own.
Kelly
Re: Comments/Issues
Thanks for your feedback. I have forwarded the details of the missing welcome page and sound tab to our developers team.
Return to “BETA: Presentations for Android”
