Presentations in Chromeos
PepsimaxMJS
Post by PepsimaxMJS »
OK so I have side loaded into Chromeos on Acer Spin 713. When running the app the pointer shows the text selector icon rather than a mouse icon. This means some 'drag options' cannot work.
Well done on the User Interface settings. Can precisely configure to best suit high dpi screens. Very good result on my machine.
Re: Presentations in Chromeos
Thanks for your feedback. Currently, Chrome OS is not supported but the problem you mentioned of pointer is already reported to our developers team.
Return to “BETA: Presentations for Android”
