How to install silent mode with using the activation code?
Post your questions, bug reports and suggestions here for FreePDF for Windows.
itaching
Post by itaching » Mon Nov 23, 2020 6:24 am
We would like to deploy it via SCCM. But the script for that how to achieve? Could you please share the command for that?
Or is there can using the another method to do that? Like insert an email address in the task sequences or installing with specify .xml config files... ...etc
Thanks.
Re: How to install silent mode with using the activation code?
Post by SuperTech » Fri Nov 27, 2020 4:32 pm
Currently, we don't support deployment using SCCM but I have forwarded this feature request to our product management...
itaching
Post by itaching » Tue Dec 01, 2020 2:11 am
Thanks for your informations. If current no support SCCM deployments its ok. But is that possible silent install via command with free activation code or with specified xml config files ... etc
Post by SuperTech » Tue Dec 01, 2020 8:41 am
We have this feature but only in FlexiPDF. FreePDF can't support such enterprise feature.
Return to “FreePDF for Windows”
