Removing Form Editing
Post your questions, bug reports and suggestions here for FreePDF for Windows.
dawnmski
Post by dawnmski » Thu Sep 10, 2020 4:51 pm
Is there a way to remove the option to edit a form once you've filled it out? I am having a problem when I send someone a PDF form that I've filed out - the info I've filled in is missing. Can I remove the editing option when I'm done to create a final PDF? I've tried going into security and unchecking the editing box but that doesn't seem to change anything.
Re: Removing Form Editing
Post by SuperTech » Thu Sep 10, 2020 10:26 pm
The only option I can think is once you filled the entire form, just take a print to PDF file so that the editable filled form will be converted into an uneditable PDF document which user will unable to edit using reader software.
Return to “FreePDF for Windows”
