Creating a new document
Post your questions, bug reports and suggestions here for FreePDF for Windows.
bburkett
Post by bburkett » Tue Apr 14, 2020 8:05 pm
I have just downloaded and installed FreePDF.
I want to create a new document, but have no option to do so.
A search in "Help" shows there should be an option to create a new, blank PDF document:
"Choose File > New, then choose Blank."
I do not have that menu option. Am I missing something? The software is registered.
Note: The User Manual link in "help" leads to manual for FlexiPDF.
Also, I want to be able to create documents, insert screen shot images and annotate them with notes and markup items such as arrows.
Does FreePDF support this?
Thanks in advance for your time.
Regards,
Bob Burkett
Re: Creating a new document
Post by Woody44 » Wed Apr 15, 2020 3:51 am
I have FlexiPDF Basic 2017, and I don't have the option to create new documents. In fact, I can't even edit text in an existing document. I suspect that the option to create new documents exists only in the Pro version of FlexiPDF.
Post by SuperTech » Wed Apr 15, 2020 4:52 am
Thanks for showing interest in FreePDF. You can create blank documents only in our FlexiPDF software (Standard and Pro alike).
You can find comparisons of FreePDF vs FlexiPDF by clicking on the below mentioned link:
https://www.softmaker.com/en/comparison ... f-flexipdf
To purchase FlexiPDF please click on the following link: https://www.softmaker.com/en/shop-flexipdf
Return to “FreePDF for Windows”
