Text Borders not showing correctly
Post your questions, bug reports and suggestions here for FreePDF for Windows.
Dimps
Post by Dimps » Fri Mar 20, 2020 2:19 pm
Hi, I've created a document in TextMaker which includes several paragraphs of text with borders. This appears okay in TextMaker and I see no problem when I export the file to Foxit PDF Reader ... but with FreePDF the borders on the right or left (or both) are sometimes omitted. Obviously this looks very unprofessional.
Do I need to go back and change all my paragraph indents (aargh! :cry: ) to something like 0.5cm or is there a fix in FreePDF?
Re: Text Borders not showing correctly
Post by SuperTech » Sun Mar 22, 2020 7:42 pm
Please send us your TextMaker and FreePDF files on which you have this issue. If you would like to send it to us privately, please send us an e-mail to forum[at]softmaker.de
viewtopic.php?f=352&t=19658
Dimps
Post by Dimps » Mon Mar 23, 2020 2:11 pm
Thanks for the reply SuperTech!
I've attached two files showing a sample of the text borders in .TMDX and .PDF formats.
EDIT: I've also tried changing the “Paragraph Indent” from 0cm to 1cm but the left and right hand borders still do not appear on FreePDF.
Dimps
Forum-file.tmdx
(364.77 KiB) Downloaded 33 times
Forum-file.pdf
(157.73 KiB) Downloaded 30 times
Post by SuperTech » Tue Mar 24, 2020 3:23 pm
Thank you for reporting this issue. I have shared this with our development team.
Dimps
Post by Dimps » Wed Mar 25, 2020 2:03 pm
Thanks ... I will revert back to using FoxitPDF until the problem is fixed, and look forward to hearing if there is a "fix".
Dimps
Post by miguel-c » Tue Mar 31, 2020 5:51 pm
The issue you reported has been fixed and the fix will be included in the next update (or the following)
Return to “FreePDF for Windows”
