Flattening PDFs with FlexiPDF 2019?
Questions and answers about FlexiPDF 2019 for Windows
xor
Post by xor » Mon Mar 22, 2021 7:16 pm
Is it possible to "flatten" PDFs with FlexiPDF 2019?
"Flatten" means to merge all the document layers into one, for example to make it less easy (though not impossible, of course) to copy-paste images out of a PDF.
Re: Flattening PDFs with FlexiPDF 2019?
Post by SuperTech » Mon Mar 22, 2021 7:40 pm
Yes, the best possible way to "flatten" any PDF is to print it to a PDF file in which you can use FlexiPDF virtual printer and all the content will be flat in the new PDF file.
xor
Post by xor » Mon Mar 22, 2021 8:17 pm
Thanks for the quick answer!
Return to “FlexiPDF 2019 for Windows”
