Hello All
is there any function to mirror/flip PDF page or FLIP Word Documents!
Horizontal Flip - Text
Horizontal Flip - Images
Horizontal Flip - Vector Artwork
Converts PDFs written in Latin-text (left-to-right) into Arabic, Hebrew, Persian and Urdu text.
so that FlexiPDF automatically re-aligns text and reformats every page to ensure the correct reading order for the target language direction.
similar to this screenshot.
2/ XLIF support
New Feature:
PDF Translation Using XLIFF Export/import
XLIFF - is an industry-standard format used by professional translation tools.
open a PDF then export the XLIFF version of it.
Then Translate it using your own tools - SDL Trados Studio, memoQ, Memsource, etc.
XLIFF import to PDF - reinsert - import your translated XLIFF and FlexiPDF will inject it back into the original PDF, replacing and reformatting the text as it goes. You get a new PDF back containing all the original artwork, colors, and other high-end pre-press information, but in a new language. considering RTL requirements
is there any plan to Support RTL !
Regards
this white paper is discussing RTL specifications
https://www.adobe.com/content/dam/acom/ ... epaper.pdf
Flip PDF page contents Horizontal / Vertical
Re: Flip PDF page contents Horizontal / Vertical
Derzeit haben wir diese Funktion nicht, aber ich habe diese Anfrage an unser Produktmanagement weitergeleitet...
