Difficulty deleting selected text inside previously created and saved text box
Questions and answers about FlexiPDF 2019 for Windows
ecbritz
Post by ecbritz » Wed Sep 09, 2020 7:00 pm
Please read the attachments where I explain & illustrate my problem.
Select for deletion.pdf
(397.99 KiB) Downloaded 48 times
Softmaker 2016 & 2018.
Re: Difficulty deleting selected text inside previously created and saved text box
Post by SuperTech » Thu Sep 10, 2020 10:25 am
Thanks for sharing the file but I can't check much in the attached file as it's not the original one.
If your PDF document is already in text format you can just click before that character and delete using the delete key if not please OCR the file by menu command Document > Recognize Text (OCR). After the complete text recognization, you will able to delete the character if the text is recognizable.
ecbritz
Post by ecbritz » Fri Sep 11, 2020 11:50 am
Thanks. I tried to work on a pfd received from a school and do not know if the relevant characters were in some text or "editable" box or mode. I solved the problem by simply deleting what I was forced to delete, then replacing what was deleted with the same thing slightly changed. I'll return to this issue if & when I encounter it again.
Return to “FlexiPDF 2019 for Windows”
