I can no longer open FlexiPDF 2019, v2.07 (latest download). I receive the error message: "The code execution cannot be processed because mfc140u.dll was not found. Reinstalling the program may fix this problem."
I tried reinstalling => same error.
I tried uninstalling, then reinstalling => same error.
I've read the issue might be related to Microsoft Visual C++
I currently have "Microsoft Visual C++ 2015-2019 Redistributable" for x86 and x64 installed.
Running Windows 10 Home, Version 2004, OS Build 19041.388, Windows Feature Experience Pack 120.2202.130.0
I do find a copy of mfc140u.dll in C:\Windows\System32
Looking at Properties/Details, It is version 14.22.27821.0 dated 6/20/2019 7:05pm, part of Microsoft Visual Studio 2017
Tried copying mfc140u.dll to FlexiPDF 2019 folder and got different error:
"The application was unable to start correctly (0xc000007b). Click OK to close the application."
Then copied mfc140.dll to FlexiPDF 2019 folder and got different error:
"The code execution cannot proceed because mfc140u.dll was not found. Reinstalling the program my fix this problem."
Thank you for any suggestions!
