SOLVED: What does the UNDO button undo?
On the left side of the T-button there is a button that looks like an Undo-button. But what does it undo? I have to close the file I am working on in order to start again and re-do what I was doing. The button does not seem to undo anything. Perhaps it has another function?
Softmaker 2016 & 2018.
Re: What does the UNDO button undo?
This is the Rotate tool. It allows to rotate objects freely in steps of single degrees.
Thanks. I am setting functions I probably won't use, such as "rotate" and "side-by-side comparison", aside for the time being. Undo, however, is something I would like to be able to do, so I don't have to quit and re-open a file every time I make a mistake. Is it possible to undo steps that need to be redone, i.e. take a step back?
Yes, you can perform undo by using shortcut key combination Ctrl+Z or you can use Menu Edit > Undo.
Thanks! That is great! Is there also a way -- perhaps a shortcut -- to undo undo, i.e. recoup what you have undone?
Undo operation is not reversible and can't be undone.
Thanks, wonderful support even after hours!
