When i try to open a 3.778 Mo file, FlexiPDF stops working and my only option is to close it.
Does anyone have a suggestion about this problem ?
Is it a frequent problem ?
Thanks !
The file does not open at all. I see the software counting the pages and then i get a message that the software must be closed.miguel-c wrote: ↑Tue Mar 03, 2020 10:56 amI wasn't able to reproduce the issue with your file on FlexiPDF 2.0.5 on Windows 8.1
I suggest you install https://aka.ms/vs/16/release/vc_redist.x86.exe and try again.
PS: Does it happen as soon as you open the file, or only during editing?
I installed the file you suggested. I still cannot open the file you opened but i opened other files of 6.2 Mo and 9.2 Mo but others would not open and the software had to be closed. All this is bizarre !atentale9 wrote: ↑Wed Mar 04, 2020 5:50 pmThe file does not open at all. I see the software counting the pages and then i get a message that the software must be closed.miguel-c wrote: ↑Tue Mar 03, 2020 10:56 amI wasn't able to reproduce the issue with your file on FlexiPDF 2.0.5 on Windows 8.1
Thank you Miguel-c. I will be waiting for this service pack. Any approximate idea of when i could be receiving it ?
