Still cannot use print driver in New v2.0.5
Post your questions, bug reports and suggestions here for FlexiPDF 2019.
johnUSA
Post by johnUSA » Wed Aug 14, 2019 10:52 pm
As with previous PlexiPDF versions I still cannot save any file as a PDF by using the print driver in this just released 2.0.5 version.
After selecting FlexiPDF printer from my printers drop-down menu and clicking on the "Print" button absolutely nothing happens.
I should see a new window pop up where I will be able to type the new PDF file name so it will be saved.
So disappointed that this issue still lingers on even with today's newly released 2.0.5 version.
Re: Still cannot use print driver in New v2.0.5
Post by miguel-c » Wed Aug 14, 2019 11:52 pm
Hi John, unfortunately you are the only user affected by this. The fix worked to all other users who had this problem:
https://www.softmaker.com/en/tips-flexipdf
In a future version we will implement a procedure to check if printdisp has been disabled on the system.
Return to “FlexiPDF 2019”
