closed pdf file reopens at first page
Questions and answers about FlexiPDF 2019 for Windows
anvil
Post by anvil » Thu May 09, 2019 11:01 pm
How do i set up the ability for a reopened pdf to open on the page it was closed. meaning, if i close on page 8, how do i set it up to reopen on page 8.
also, How do i set up bookmarks so it opens to "fit Width". I am set up so all files open to "fit width", and my new bookmarks open to the proper zoom level[fit width], but if there is a preexisting bookmarks list, it opens to "stock" zoom.
Thanks in advance.
Re: closed pdf file reopens at first page
Post by martin-k » Mon May 13, 2019 10:09 am
Issue #1: This is currently not possible.
Issue #2: I cannot reproduce this. Here is what I did:
1. I set the default zoom to "Fit width", "ignore setting in PDF".
2. I opened a PDF without bookmarks -> it was loaded with "Fit width" zoom, which is correct.
3. I then created an automatic bookmark list, reduced the zoom (to be able to see a difference later), saved the document and reopened it.
The document again correctly appeared with "Fit width" zoom.
Please provide step-by-step instructions and a sample file, and I will try to reproduce your problem.
Return to “FlexiPDF 2019 for Windows”
