Snap to other objects
Post your questions, bug reports and suggestions here for FreeOffice TextMaker 2018 for Linux.
vincenzo.caselli
Post by vincenzo.caselli » Thu May 24, 2018 1:18 am
Hi,
first of all: compliments for the great product!
Now the question:
is it possible to snap one object to other objects, like in
MsOffice PowerPoint
https://support.office.com/en-us/articl ... 59ecbe95e3
or in
WPS Office
http://help.kingsoftstore.com/presentat ... ning-slide
Thank you very much.
Regards
Vincenzo
Re: Snap to other objects
Post by sven-l » Mon May 28, 2018 1:21 pm
Snap to obejcts is supported in SoftMaker Office but not in FreeOffice. As a workaround you can group objects like graphic frames (just select all objects, then right mouse click on the selection and choose "group".
vincenzo.caselli
Post by vincenzo.caselli » Tue May 29, 2018 10:05 am
Ok,
thank you Sven.
Best regards
Vincenzo
Return to “FreeOffice Presentations 2018 for Linux”
