VLOOKUP() function not working between two different files
Questions and answers about FreeOffice PlanMaker 2018 for Linux
DanielFiresword
Post by DanielFiresword » Sun Feb 07, 2021 5:33 pm
I am currently using SoftMaker FreeOffice for Linux, and I am facing an issue with VLOOKUP. I have a critical use case where I am required to fetch certain data into a spreadsheet (sheet 1) using data from a different .xlsx file (sheet 2), which I also opened in PlanMaker. However, I am unable to enter in the reference table (located in sheet 2) as per the formula
Data to enter in Sheet 1 =VLOOKUP(<RefCell in Sheet 1>, <Ref table in sheet 2>, column no, 0)
I would like some help in this regard. Could someone point me to a solution to this problem? Or is it a bug?
(sorry for bad grammar, my first language is not English)
Re: VLOOKUP() function not working between two different files
Post by SuperTech » Wed Feb 10, 2021 7:10 pm
Please let us know these Sheet1 and Sheet2 are in the same file or different?
DanielFiresword
Post by DanielFiresword » Thu Feb 11, 2021 11:20 am
Sheet1 and Sheet 2 are in two different files. Sheet 1 is in File 1, and Sheet 2 is in File 2.
Post by SuperTech » Thu Feb 11, 2021 6:45 pm
Please use this Formula syntax =VLOOKUP(Matching Cell,'Target File path[Target File Name with ext.]Worksheet name'!Range,n,Sorted)
For example : VLOOKUP(G13,'D:\MyFiles\[temp File.xlsx]Sheet1'!$K:$L,2,0)
DanielFiresword
Post by DanielFiresword » Sat Feb 13, 2021 9:31 am
Thank you!
Is there any way I can automatically get that file location? In MS-Excel, if I select a range from another sheet, it automatically inputs the file location/path into the formula, instead of manually adding it. Would appreciate it if I can get something like that in PlanMaker.
Post by SuperTech » Sun Feb 14, 2021 7:19 pm
Thanks for your suggestion. I have forwarded this feature request to our development team.
Return to “FreeOffice PlanMaker 2018 for Linux”
