Spell checking in PlanMaker.
jairoraiol
Post by jairoraiol » Fri Sep 20, 2019 3:05 am
First of all I want to say that I admire this work very much.
Verification is working in TextMaker and Presentations.
However, I couldn't make it work in PlanMaker.
I also expected to see the same fields in the language setup tab, as in PlanMaker this tab is slightly different compared to the other two applications.
Grateful for the attention.
Jairo Raiol
OS: Linux 64bit (DEB)
Language: Portuguese (Brazil)
Re: Spell checking in PlanMaker.
Post by miguel-c » Fri Sep 20, 2019 12:19 pm
Hi, we have just released revision 971 of FreeOffice that fixes that issue.
jairoraiol
Post by jairoraiol » Fri Sep 20, 2019 10:20 pm
Hello! Thanks for answering.
What was previously reported was observed after the update I received on 9/19/2019 (rev 971.0912).
Therefore, I believe that during my tests, I was already using the version of the latest release.
Is it right?
Jairo Raiol.
Post by miguel-c » Sat Sep 21, 2019 2:22 pm
Hi, you may need to go to File | Options | Language and check if you have the correct Hunspell dictionary installed
jairoraiol
Post by jairoraiol » Sat Sep 21, 2019 6:11 pm
Hello!
That's exactly what I did the day FreeOffice was updated (9/19/2019).
Soon after, finding that the dictionary of my language was already present, as I had already added it in TextMaker previously, I performed new tests.
Then I realized that the problem was still occurring.
Jairo Raiol
OS: 64-bit Linux (DEB)
Return to “FreeOffice PlanMaker 2018 for Linux”
