Spell Check Bug
Questions and answers about FreeOffice TextMaker 2018 for Linux
BT_TEC
Spell Check Bug
Post by BT_TEC » Sun Nov 17, 2019 5:26 pm
Hi, so using text maker rev 973.1103 on debian 10 buster.
Spellchecker is not working at all. Even after I downloaded the latest hunspell dictionary.
After installing English dictionary, even if I introduce errors, nothing is spotted. Then the dictionary shows as Indonesian, even though that dictionary is not installed.
Can someone fix this, as it makes freeoffice unusable if I have to manually check everything 1 textbox at a time.
Re: Spell Check Bug
Post by miguel-c » Sun Nov 17, 2019 7:12 pm
Hi, you can activate background spell-checking on File | Options | Language |Use background spell checking.
Also, while there please make sure that the correct language is chosen.
Return to “FreeOffice TextMaker 2018 for Linux”
