Unable to set the default character font.
Questions and answers about FreeOffice TextMaker 2018 for Linux
jairoraiol
Post by jairoraiol » Fri Aug 09, 2019 4:54 am
Hello everybody.
First of all, I want to say that I am really enjoying this product.
Within the app, when I try to change the font for all new documents, I get the following message:
"The file /home/jairo/SoftMaker/Templates 2018/Português/Normal.tmvx cannot be opened."
This path is incorrect.
The subfolder "Português" does not exist.
This subfolder, on this path, should be called "Português (Brasil)", and this other one exists. I confirmed when I looked inside the "Templates 2018" subfolder.
And changing the template files in the right way didn't solve the problem either.
Grateful for the attention.
Jairo Raiol
OS: Linux 64bit (DEB)
Re: Unable to set the default character font.
Post by miguel-c » Fri Aug 09, 2019 7:08 pm
Hi, I'm going to report the issue to the developers, thank you.
Post by miguel-c » Fri Aug 16, 2019 5:53 pm
Hi, we fixed the issue and the fix will be included in the next service pack for FreeOffice. Thank you for your feedback!
jairoraiol
Post by jairoraiol » Fri Sep 20, 2019 2:31 am
I thank you too.
And congratulations on the great work.
Jairo Raiol
Return to “FreeOffice TextMaker 2018 for Linux”
